Two waterproofing solutions for underground drainage
A proven waterproof solution is essential for safeguarding basements, car parks, tunnels and other belowground concrete structures against damp and water ingress. But which system is best suited to your building? A render-based product? A drainage system incorporating a membrane? Sika offers both solutions as part of its proven, wide-ranging concrete and waterproofing range, so let's examine the benefits of each.
Sika®-1 Pre-Bagged waterproofing system comprises watertight renders and screeds produced using the Sika®-1 Waterproofing Liquid and Sika®-1 Pre-Batched Mortars. The mortars consist of a blend of special cement and kiln dried graded aggregates. Packaged in four grades, each is specifically designed for optimum application performance and durability.
Key considerations when specifying Sika®-1 Pre-Bagged:
- Once applied, it requires absolutely no maintenance
- It is more cost-effective when applied to areas of 300m2 or less
- The render system takes up minimal space
- Bonds directly to the substrate – follows the contours of any structure
- Withstands high water pressure
- Substrate preparation may be required
In terms of a water management solution, Sika® CD-Cavity Drain System uses a high density polyethylene internal drainage membrane to control water after it has penetrated a structure. The system is installed, loose-laid in flooring applications and attached to the wall with surface plugs in vertical installations. The system directs penetrating water into a drainage system and a collection sump before using a pump to discharge water from the building. A cavity drain provides protection from the ingress of water, vapour and gases.
Key considerations when specifying Sika® CD-Cavity Drain System:
- System requires ongoing maintenance and running costs
- Requires more space to install
- Acts as a vapour barrier
- Limited surface preparation required
- Can be used where the substrate does not have the strength to resist stresses caused by water pressure
- Most cost-effective on areas larger than 300m2
Although varying in application and comprising different materials, the systems share common properties. For instance, Sika®-1 Pre-Bagged and Cavity Drain are suitable for new-build and refurbishment projects involving a range of belowground structures.
As well as being BBA-approved, both systems carry a Sika guarantee when installed by an approved contractor. Other common properties include the systems' suitability for use to grades 1-3 according to BS 8102-2009, and high water table according to BS 8102-2009.
What then, must we conclude from this comparison? Well, by eliminating the need for ongoing maintenance, the Sika®-1 Pre-Bagged system is a more cost-effective solution over a lifespan of 60 years, particularly for structures 300m2 and below.
Not as simple to apply as the pre-bagged system, on account of its additional components, Sika® CD-Cavity Drain System is a more ideal waterproofing solution for areas larger than 300m2. Ongoing running costs are incurred, as the system requires regular maintenance.
Sika®-1 Pre-Bagged or Sika® CD-Cavity Drain system…whichever system you choose as your belowground solution, you are guaranteed the same quality: superb, long-term waterproof performance.
- Sika operates a Registered Contractors scheme, designed to help facilitate the selection of suitable contractors to install Sika waterproofing systems including Sika®-1 and Cavity Drain. Choosing a Sika Registered Contractor provides total quality control – from product to service and installation – giving clients added reassurance that they will receive the highest standards of professionalism at every stage.
Visit: https://www.sikawaterproofing.co.uk/products-systems/sika-cd-cavity-drainage-system/
Read moreThe Psychology of Construction and Why We Accept Inefficiency
