Supporting the UK housing drive with faster and safer concrete solutions
The government has set a clear target: 1.5 million new homes in England this Parliament, which works out at around 300,000 a year. Reforming the planning system is only part of the answer. Delivering homes at that scale also depends on how quickly and safely they can be built, and that puts the spotlight on the methods used on site, starting with the ground floor slab.
Where a residential design incorporates reinforced concrete base or floor slabs, forming the slab edges efficiently can help the groundworks programme progress more predictably. Conventional edge formwork must be cut, fixed, supported and then stripped once the concrete has cured. Each stage takes labour and handling time, and across developments involving repeated slab construction, reducing these activities has the potential to deliver cumulative labour and programme benefits. The actual saving will depend on the project design, quantities and site sequence.
A permanent approach to slab edges
RECOSTAL® Speed Edge from DYWIDAG takes a different approach. It is a permanent lateral formwork for reinforced concrete base and floor slabs, made from galvanised steel sheet and supplied in 2.25 m units in heights from 14 cm to 50 cm. Because it remains part of the finished slab, no stripping is required after concreting.
Units are positioned on the blinding layer and fixed with nails driven through holes in the base of each unit. Joints are formed by overlapping adjacent units by 3–4 cm. Corners are created on site by cutting the sheet metal base and bending the unit to shape, allowing a wide range of slabs to be formed without bespoke components. For standard installation heights up to 50 cm, Speed Edge is self-supporting, a performance confirmed in concreting tests. For pours of up to 100 cm, it is available with external support.
The speed benefit is significant. DYWIDAG’s figures show that installing a metre of Speed Edge is up to six times faster than the traditional method. The system requires only one installer and no crane. The permanent formwork arrangement can also reduce the working space associated with installing and stripping conventional shuttering on suitable designs, potentially reducing subsequent backfilling requirements.
Safer, more dependable and built for scale
Speed matters little if it comes at the expense of safety, and here the design works in the housebuilder’s favour. Removing stripping activities and crane handling can reduce exposure to some of the hazards associated with conventional formwork. With Speed Edge, no additional support is required for standard installation heights when the system is installed and concreted in accordance with DYWIDAG’s technical guidance. Installation must still be carried out in accordance with the project's safe system of work, including appropriate PPE and manual-handling controls.
That predictability can be particularly valuable on housing developments, where similar construction sequences may be repeated across multiple plots. With 14 standard height options and corners formed on site, Speed Edge can be adapted to different slab depths and layouts while maintaining a consistent installation approach.
Beyond the ground floor slab
Speed Edge addresses one part of the concrete construction process. Some residential developments also incorporate larger in-situ reinforced concrete elements that require conventional formwork. For these applications, DYWIDAG® Form Ties provide a separate solution for securing formwork under load. DYWIDAG® Form Ties are based on the original DYWIDAG® Threadbar, a hot-rolled bar with a split thread on both sides, and are used by formwork manufacturers around the world.
The coarse thread does not run around the full circumference of the bar, making it resistant to damage and dirt and effectively self-cleaning, a practical advantage in site conditions. The bar can be cut at any point and used continuously with nuts or couplers, while the high thread pitch allows connecting and anchoring components to be assembled and disassembled quickly. A characteristic tensile strength of 1,100 N/mm² provides high load capacity relative to the bar's low weight per metre, helping to keep components manageable during installation.
The system is compliant with DIN standards and quality-controlled in Germany. Accessories are available in diameters of 15, 20 and 26.5 mm for applications ranging from standard formwork fixing and recoverable systems with water stops and cones to climbing formwork anchor points and single-sided anchoring. As with all load-bearing formwork components, DYWIDAG specifies that form ties and accessories should be used by qualified and experienced operatives and inspected regularly for wear.
Hitting national housebuilding targets will require progress across planning, finance, labour and supply chains. Construction productivity also has a role to play. Across developments where the same operations are repeated from plot to plot, relatively small improvements in installation and site handling can accumulate across a wider programme. Engineered formwork systems are one practical way of addressing those efficiencies.
If you are planning a residential development and want to speed up your groundworks without compromising on safety, get in touch with the DYWIDAG team to discuss how RECOSTAL® Speed Edge and DYWIDAG® Form Ties could work on your project.
Read moreWayfinding: The importance of accessible and inclusive design
The compliance rule digital forgot
Electronic
signatures are legally valid, but on audit day, what counts is what your
accrediting body accepts, writes Zak Siddique, Product Manager at
Onetrace.
