Your building condition assessment may identify dozens of defects while leaving repair dates and funding decisions unresolved. Turning that assessment into a phased works plan gives you a way to connect each finding with its priority, projected cost and place in the schedule. A reserve study can support that process by linking future repair needs with long-term budgeting.
Review Your Building Condition Assessment Findings
Create a master spreadsheet with one row per asset, grouped by system, and include these details:
- Component: Record the asset, location and system, including architectural, structural, envelope, electrical, mechanical, plumbing, accessibility and safety findings.
- Condition: Apply consistent ratings and record estimated remaining useful life.
- Cost: Enter the estimated repair or replacement amount.
- Urgency: Note recommended deadlines and reported risks.
You can use the Facility Condition Index (FCI) to quantify overall condition across assessed systems. Calculate FCI by dividing deficiency costs by current replacement value and multiplying by 100.
Prioritize Repairs by Risk and Urgency
Escalate immediate safety hazards for professional review before scoring routine repairs. From there, consider compliance and operational consequences. For example, allocate 45% focus on physical condition and 36% to user impact. You can also give 15% to failure’s impact on building fabric and the remaining 4% to building use.
Set criteria appropriate to your property. When scores tie, prioritize work that protects other assets from further damage.
Prepare a Reserve Study to Prioritize Repairs
When you need to prepare a reserve study to prioritize repairs, consider a consultant who offers both physical and financial analyses. The Falcon Group, a multidisciplinary engineering, architectural and consulting firm, connects reserve planning with building-assessment expertise. Its explanation describes capital reserves as a savings account for major, nonannual projects. Your study combines component condition, remaining life and projected costs with a funding analysis.
You can see a reported application in its New Jersey association example, where uncertainty about meeting future capital needs prompted forecasting and reserve planning. The Falcon Group reports that the board gained confidence in prioritizing projects and planning future funding.
Estimate Costs for Each Repair or Replacement
Request cost ranges from qualified estimators or engineering consultants for your prioritized scopes. For example, Rockwise Strategies estimated the costs for Lee & Rose Warner Coliseum upgrades from schematic design through construction documents, covering roofing, restrooms, seating and infrastructure improvements. Use comparable project-specific detail to compare immediate affordability with future funding needs.
Sequence Your Repairs into a Phased Schedule
Order your phases around urgent risks and physical dependencies. An envelope-first principle supports making the building weathertight before applying interior finishes. This is because walls, roofs and foundations affect 28% of building energy use.
Keep projected savings specific to your building’s condition and proposed work. Record dependencies and contingency allowances alongside each phase.
Bid and Schedule the Work with Qualified Contractors
Issue a defined scope for each phase and compare bids against your funding timeline. Check licensing, local registrations, financial capacity and similar completed work. For a scope example, KE&G’s Oro Valley pipeline project included over 4,200 linear feet of ductile iron main plus cathodic protection, testing and restoration. Ask bidders to account for comparable supporting tasks within your own scope.
Frequently Asked Questions
Use these checks when reviewing your plan. Keep your provider’s scope aligned with your assessment findings.
Who can prepare a reserve study?
You can approach specialist reserve study consultants or engineering firms offering reserve analysis. Check relevant building experience and the proposed assessment scope.
What should a reserve study proposal include for repair prioritization?
Request a component inventory, condition review, cost projections and funding analysis. Ask how urgency, life-safety risk, physical condition and financial readiness will inform priorities.
How do you prioritize repairs from a condition assessment?
Rank your findings by safety risk, compliance needs and operational impact. Use asset protection as a tie-breaker when priorities overlap.
Why should you phase repairs into stages instead of all at once?
Phasing can align your spending with available funding and construction dependencies. Complete protective work before dependent finishes to reduce potential rework.
Put Your Phased Works Plan Into Action
Open your assessment report and build the component inventory today. Rank repairs, obtain estimates and reconcile those costs with your reserve study before confirming phases. Then seek qualified bids and assign realistic dates, giving your board a documented basis for funding and scheduling decisions.
Read moreThe Psychology of Construction and Why We Accept Inefficiency
