How to waterproof conservatories, balconies, terraces and walls
Protecting properties from the elements can be a costly and time consuming process. Mother Nature is relentless and will quickly expose weak spots on any building ensuring that water ingress will always win – if you let it.
Roofs, conservatories, balconies, terraces and walls are extremely prone to water penetration and left alone will ultimately result in major refurbishment. Until fairly recently construction professionals would use a variety of different sealants to tackle an equally wide variety of leak situations, but thankfully science has come to the rescue.
There are several companies that have developed advanced ranges of waterproofing solutions that can be simply brushed or rolled onto surfaces, seeping into cracks and other vulnerable areas to produce a barrier, once fully cured, against even the worst weather.
Many of these solutions are transparent and virtually invisible once applied which makes them ideal for all types of glass such as conservatory roofs and roof lights. They can also be used on terraces and exposed brickwork helping to enhance the colour of the stone while adding total protection.
The good thing is that such solutions can be applied by without any special skills saving householders massive labour costs, but as in all cases, particularly when a leak is at roof level, it is usually best to call in the professionals.
If you are planning to do it yourself then make sure that you have enough material; to complete the job. A 20Kg tin will cover around 25 sq metres of surface area depending on the thickness of the coating. Ensure that everything is cleaned up before any solution is laid to ensure maximum performance and ideally three layers should be used on the surface area.
Coverage is based on application by roller onto a smooth surface in optimum conditions. Factors like surface porosity, temperature and application method can alter consumption.
Installed correctly your roof, conservatory, balcony, terrace or wall will continue to giver many more years of service keeping out the worst of the weather.
 If you are looking for such a product then why not check out Maritrans, which is available via Amazon.
Click here for Amazon
