Installing the Right Fire Extinguisher for Your Business: What You Need to Know
When you become a business owner, you take great care in protecting your business as well as employees. Part of the protection needs includes fire safety. To keep your business safe, elements of fire safety are added, including smoke detectors, fire alarms, and fire extinguishers. Did you know that there are several types of fire extinguishers? Because fires can be caused by varying elements, it is important to have the right extinguisher type within your business. Get to know the options below to ensure you are protecting your business the right way.
Most people think that every fire extinguisher is the same. They look at an extinguisher as a way to put out the flames. However, there are five different types, each belonging to a certain class. Understanding the classes and what type of extinguisher you need for your business is essential or fire safety.
Class A
This type of fire extinguisher is used for fires involving combustible materials. This can include fires that involve straw, paper, and textiles. When you operate a business that uses these types of materials, then you can benefit from this type of extinguisher.
Class B
This type involves fires where flammable liquids are at play. This would include fire with fats, tar or petrol. Only this type of extinguisher will put out fires involving flammable liquids. If you work with such materials, this type should be on hand.
Class C
This type of fire extinguisher will work on fires that involve flammable gasses. Natural gas, propane and methane fires can be put out with this type of unit. Certain chemicals are placed inside this fire extinguisher to counteract with the flammable gas chemicals.
Class D
This type of fire extinguisher reacts to fires involving flammable metals. This would include fires with potassium, metal, and aluminium. If you own a business that works with such materials, then this type of fire extinguisher must be on hand.
Class F
This extinguisher type involves fires from cooking. This could be in a domestic setting or from a deep fryer. The extinguisher also works with electrical fires. Any fires started from electrical components or appliances will react to this extinguisher type.
Fires are separated based on classes due to how the fire needs to be managed. There is unfortunately not just one way that a fire can be treated. In certain scenarios, fighting a fire with the wrong class of extinguisher can see the flames grow. Take for example a cooking-related fire. With a Class F fire, if you use a water extinguisher, the fire will be exacerbated.
Fire Extinguisher Types
It is essential to choose the right fire extinguisher for your business needs. With so many types available, it can be confusing. A water type can be used for Class A fires. However, using this type of extinguisher requires care. Be sure to avoid any electrical components as the water can be a conductor for electricity. This type of unit will have the word WATER displayed on the side.
Another type of extinguisher is AFFF Foam. This type will work for Class A and Class B fires. This type is known for helping to prevent fires from reigniting by creating a foam blanket on the fire to stop the oxygen supply.
Carbon Dioxide fire extinguishers are another type, one that will work for Class B and Class C fires. This type is basically ineffective for a Class A fire. ABC extinguishers are another type, one that will work for Class A, B and C fires. This one is beneficial to businesses that might be at risk of these types of fires.
Additional fire extinguisher types include water mist, wet chemical and specialist dry powder. Each of these types will provide fire safety for a specific class of fires. Water mist and dry powder work for Class D while the wet chemical will work for Class F.
When it comes to your business, it is important to have the right fire extinguisher on hand. Speak to a specialist today about your options.
