Fabric first design key to thermal efficiency
The Future Homes Standard (FHS) is a bold step in the UK’s journey to net zero. Set to become mandatory for all new homes in 2025, the standard is an opportunity to deliver much needed energy efficient housing and stay on track with our climate ambitions. Making sure the envelope of a building is as good as it can be is essential with attention to detailing and thermal bridging eliminating some of the issues that create poorly performing homes. As part of this fabric-first approach to design, a one piece thermally-efficient lintel can significantly improve SAP ratings and eliminate the need for costly renewable technologies writes Ciaran McAliskey, Specification Manager at Keystone Lintels.
The Future Homes Standard (FHS) is a bold step in the UK’s journey to net zero. Set to become mandatory for all new homes in 2025, the standard is an opportunity to deliver much needed energy efficient housing and stay on track with our climate ambitions. Making sure the envelope of a building is as good as it can be is essential with attention to detailing and thermal bridging eliminating some of the issues that create poorly performing homes. As part of this fabric-first approach to design, a one piece thermally-efficient lintel can significantly improve SAP ratings and eliminate the need for costly renewable technologies.
The revisions to Part L requirements of the Building Regulations represent progress towards the 2025 Future Homes Standard but reaching these goals requires a focused and upfront effort on the design of a building’s envelope. The June 2022 interim Part L uplift to energy efficiency requirements demands 31% lower carbon emissions from all new homes through a combination of fabric improvements, low carbon heating and PV panels. However 2025 has spurred an even bigger transformation for new housing, with 75-80% emissions cuts mandated. To achieve such dramatic cuts now requires housebuilders to prioritise thermally efficient building fabrics from day one.
Fabric-first approach
In 2025, optimising the thermal performance of the building envelope through intelligent design and a fabric first approach is essential. Constructing an airtight, well-insulated building fabric that minimises heat loss will be key to hitting energy and emissions targets and achieving compliance, whether for large developments or individual houses.
Enhancing the building’s envelope efficiency provides more than just low emissions, it also provides occupants with superior thermal comfort and air quality. This creates more comfortable indoor spaces which in turn can enhance productivity, health, and overall wellbeing.
Building as designed
A core element of the fabric-first approach is addressing thermal bridging, which can account for up to 30% of a home’s heat loss if not managed correctly. Eliminating thermal bridging through intelligent design and correct product specification will be vital to meet these ambitious new regulations.
However, we often fail to consistently build what we design, using incorrect products or detailing. Workmanship and site skills also cause issues. This can lead to a performance gap between as-designed and as-built building performance, with weak spots significantly impacting heat loss and overall fabric performance.
The Building Regulations Part L report (BREL) details required materials that must be installed without substitution, unless the report is recreated or amended by an energy assessor. Building control can use this report as a checklist and may ask for thermal elements to be recalculated if you swap brands or material types of different thermal values.
Part L now states we use the actual thermal transmittance values for building products within the building envelope; in the past, generic ACD (accredited construction detail) values were accepted within the SAP assessment. These values could vary substantially from the actual value of a specific product. By making this change, the Y value obtained is now accurately represented within the BREL report.
Photographic evidencing
One of the stand out changes from Part L to help bridge the performance gap is the requirement of photographic evidencing of key junctions at the relevant construction stage for every new dwelling. This will need to have geo-location technology activated, and the report will be provided to building control and the building owner. Essentially, there will need to be proof that the dwelling has been constructed from the same materials that it was designed from; ensuring the property runs as efficiently as it should.
High performance lintels
Traditional steel lintels can create major thermal bridges in homes due to steel’s high thermal conductivity and typical long spans. However, solutions such as Hi-therm+ address this, setting a new standard for thermal efficiency in steel lintels. By incorporating a thermal break, Hi-therm+ is up to five times more thermally efficient than standard lintels, a cost-effective solution that will save energy over a home’s lifespan when the fabric is done right.
A recent enhancement to the Hi-therm+ Lintel is pre-fitted insulation which includes a higher content of recycled materials, boosting thermal efficiency even more. With up to 20% increase in performance, Hi-therm+ Lintels can improve overall junction Psi values by up to 15%, making them an ideal choice for a fabric-first approach to meeting modern regulations. This makes Hi-therm+ the go-to solution for contractors and housebuilders seeking high-performance, sustainable products that comply with current standards.
These lintels have significantly impacted home thermal efficiency and are specified on many housebuilder projects around the UK due to low cost and improved performance in lowering carbon emissions within the Standard Assessment Procedure (SAP). Lintel performance should not be understated, as thermal bridging can account for up to 30% of a building’s heat loss, making it a critical factor in achieving optimal thermal performance.
With energy prices contributing to inflation and the cost of living, the timing of these regulatory changes to improve home efficiency couldn’t be more critical. While housebuilders face challenges to meet ambitious new housing targets, embracing a fabric-first approach will be key to achieving sustained energy savings and fulfilling our climate goals.
